These forums are a place for learning, helping and sharing experiences with others about any of our products. Feel free to ask a question and get answers from our community and our most advanced users.
Note that these are public forums - anyone can view the discussions here.
VISIT OUR DIFFERENT FORUMS:
Announcements > | |
CloudShell > | TestShell > |
Developers > | BI (Business Inteligence) > |
This is where you can suggest your ideas to help and improve the product for everyone.
Please make sure to read the following article before posting a new idea, to get more information about the required information and ideas lifecycle.
Feel free to vote and comment on other ideas to promote them.
Thanks for everyone who suggested the ideas and voted for them.
Find, download and share integrations that can extend and enhance the CloudShell experience.
Integrations have several levels:
Certified - Officially tested and supported by Quali.
Preview - Provides a sneak peek to what the Quali team is developing. Officially supported by Quali. Feel free to experiment and comment, but please take into consideration that it is not yet tested and released.
Community - Integrations shared by community users. Feel free to look into what other users have contributed, please take into consideration that these integrations are not tested by Quali.
To learn more about creating Shells and integrating with CloudShell, use the following links:
CloudShell's Dev Guide > | Configuration Management > |
Getting started with Shells > | Extending CloudShell with Cloud Providers > |
Getting started with Orchestration > | API Guide > |
To share your integration, follow the instructions in this guide >.
I have a healthcheck function that I use for multiple resources. I am trying to run this healthcheck function parallel for different resources in a blueprint. Here is part of my code :
for command in res_commands: pool = ThreadPool(len(resources)) if 'healthcheck' == command.Name: try: if value == 'ViasatSmac': globalInputs = helpers.get_reservation_context_details().parameters.global_inputs vasn_val = globalInputs['vasn_ip'] input_name_val_command = InputNameValue('vasn_ip',vasn_val) api.ExecuteCommand(self.reservation_id, root_resource_name, 'Resource', 'healthcheck',commandInputs=[input_name_val_command]) else: # api.ExecuteCommand(self.reservation_id, root_resource_name, 'Resource', 'healthcheck') async_results = pool.apply_async(self._async_healthcheck, api,root_resource_name) except Exception as e: api.WriteMessageToReservationOutput(self.reservation_id,e.message) pool.close() pool.join() res = async_results.get() api.WriteMessageToReservationOutput(self.reservation_id,res) .
but when I ran this code I got the below error:
TypeError: _async_healthcheck() argument after ** must be a mapping, not str
I am new to multiprocessing and I am not sure what's wrong here?
and here is the function that I am using in apply_async:
def _async_healthcheck(self,api,root_resource_name): reservation_id = self.reservation_id api.ExecuteCommand(reservation_id, root_resource_name, 'Resource', 'healthcheck')
Hi @gjavadi
1. don't create the pool inside the loop - otherwise, you create a new one in each iteration. so create the pool outside of the loop, then after the loop use the pool.close/join
2. the apply_async gets the function name (_async_healthcheck) and then all of the arguments together as one argument inside parenthesizes. So in your case, it should look like this:
async_results = pool.apply_async(self._async_healtcheck, args=(api, root_resource_name))
3. the results that you get are also a list of objects to you need to iterate on them as well:
for result in async_results:
res = result.get()
print res
4. make sure you also handle the other execute command (line 9 above), otherwise it won't run in parallel to the others (or maybe just in parallel to some of them, and the others will wait for it to complete).
Yaniv
Hi Yaniv, Thank you so much for your help. I will try all of those thing and I will let you know.
Answer by Yaniv Kalsky · Sep 19, 2017 at 09:26 PM
Yes, sorry, in your case, the result that you get is not a list, so depends on where you'd like to check/print it.
so one way would be to store the results in a list:
async_results = [None] * len(resources) idx = 0 ... async_results[idx] = pool.apply_async(self._async_healtcheck, args=(api, root_resource_name)) idx += 1
then after the pool.join you can iterate as before.
The other option, if you just need to print the results, is to call a callback function when a function ends:
def print_result(result): print result
and then in your loop call the async like this:
pool.apply_async(self._async_healtcheck, args=(api, root_resource_name), callback=print_result)
Yaniv
Thank you Yaniv, the result that is an argument to the print_result is not something that I passed? it returns automatically the result from calling my function(_async_healthcheck)?
Answer by Golriz Javadi · Sep 19, 2017 at 06:03 PM
Hi Yaniv,
I have modified my code based on your comments and thanks to you it worked, but at the end I am getting another error that I am not sure:
\sandbox_scripts\environment\setup\setup_script.py", line 289, in _call_healthcheck TypeError: 'ApplyResult' object is not iterable
res = result.get()
and the other problem that I have with this, I have 4 resources that i am trying to run the healthcheck in parallel but it starts with three of them and for the fourth one it hung for a while and at the end it throws the top error?
Answer by Golriz Javadi · Sep 19, 2017 at 11:15 PM
@Yaniv.K I am so sorry that I ask so many question but when i have three modems in the same blueprint and run the healthcheck in parallel , it always hung on the last one and because i have these healthcheck on my setup script , the setup script can't finish the job? Am I doing something wrong here? I tried without adding this multiprocessing code and it can finish setup script.
Hi @gjavadi
Not sure what might cause the last one not to run/fail without seeing the whole script and knowing more about your environment (resources/drivers/how many commands slots you have/etc).
You can debug your setup script from the IDE instead of running it from CloudShell. For that, you'll need to "attach to cloudshell" in your script, read more about it here:
https://qualisystems.github.io/devguide/orchestration/8.0.0/scripts-deep-dive.html (look for "debugging scripts")
Let me know if you still have issues, or update us when you find what was the problem.
Yaniv
I did that but unfortunately the same thing happened in my main and I never get back the result. I know you are busy but if you have few minutes, can we have a quick session?
Announcements | |
CloudShell | TestShell |
Developers | BI (Business Inteligence) |
CloudShell's Dev Guide | Configuration Management |
Getting started with Shells | Extending CloudShell with Cloud Providers |
Getting started with Orchestration | API Guide |
To share your integration, follow the instructions in this guide.
