These forums are a place for learning, helping and sharing experiences with others about any of our products. Feel free to ask a question and get answers from our community and our most advanced users.
Note that these are public forums - anyone can view the discussions here.
VISIT OUR DIFFERENT FORUMS:
Announcements > | |
CloudShell > | TestShell > |
Developers > | BI (Business Inteligence) > |
This is where you can suggest your ideas to help and improve the product for everyone.
Please make sure to read the following article before posting a new idea, to get more information about the required information and ideas lifecycle.
Feel free to vote and comment on other ideas to promote them.
Thanks for everyone who suggested the ideas and voted for them.
Find, download and share integrations that can extend and enhance the CloudShell experience.
Integrations have several levels:
Certified - Officially tested and supported by Quali.
Preview - Provides a sneak peek to what the Quali team is developing. Officially supported by Quali. Feel free to experiment and comment, but please take into consideration that it is not yet tested and released.
Community - Integrations shared by community users. Feel free to look into what other users have contributed, please take into consideration that these integrations are not tested by Quali.
To learn more about creating Shells and integrating with CloudShell, use the following links:
CloudShell's Dev Guide > | Configuration Management > |
Getting started with Shells > | Extending CloudShell with Cloud Providers > |
Getting started with Orchestration > | API Guide > |
To share your integration, follow the instructions in this guide >.
I am thinking of using a feature 'Run Connected Resource Command' for non-PDU resources.
The PDU case is described here. It is not clear to me what is the significance of Tags="power"
Any experience with this feature for non-PDU resources?
Here is the use case:
- the sandbox resources (different sandboxes) are connected to a shared firewall
- the shared firewall is admin-only resource, and not part of the sandboxes reserved by the regular users
- users need to run resource commands that will do actions on that shared firewall (set ACLs, etc.)
Answer by Alona Getzler · Feb 28, 2019 at 02:33 PM
We indeed encountered requests for modelling devices that support "connected commands" outside of the PDU use case. We've just released a new shell standard to support such devices, please see this standard. To model a resource with connected commands you should use this standard, and tag the relevant commands with the tag "remove_connectivity" (not "power"). Any endpoint that will be connected (in CloudShell) to one of the sub-resources of the resource will get the connected commands.
Regarding the use case you described - can you clarify what type of "resources" you connect to the shared firewall? and why do you model the shared firewall as admin only?
Thanks,
Alona
Answer by George Rainovic · Mar 01, 2019 at 03:53 PM
Hi Alona,
Thank you for your answer.
About my use case. I'd like to connect resources of type router and switch to the shared firewall. I do not want my users to see that shared firewall or to reserve it.
About Save/Restore sandbox state of this shared resource.
Restoring state of this (entire) resource might affect other sandboxes/resources connected to this shared resource. I guess you left this to the authors of the orchestration scripts to figure out.
About Attributes, User Input
I noticed that many of the attributes listed in the table are allowed for user to change ('User Input' = yes). That might not be the optimal way to work with resource shared across multiple sandboxes (and users).
Thanks,
George
Answer by Alona Getzler · Mar 04, 2019 at 03:00 PM
Thank you for the clarification of the use case.
Regarding the Save & Restore behavior for this resource - this behavior is custom and will be defined in the setup and teardown script associated with sandbox. Do note that it won't be required to add the shared firewall to the users sandboxes in order to launch its connected commands, so practically the shared firewall can remain an "inventory resource" and booked in sandboxes only by admins for administrative tasks.
The "user input = yes" property means that the attribute's value can be populated by admin or domain-admin on resource creation and editing (in the Inventory), vs. attributes that their values can be populated only by the driver's Autoload command. Attribute which are marked as "user input = yes" won't be editable to end users.
Alona.
Answer by George Rainovic · Mar 04, 2019 at 03:14 PM
Hi Alona,
Thanks for clarifying.
Announcements | |
CloudShell | TestShell |
Developers | BI (Business Inteligence) |
CloudShell's Dev Guide | Configuration Management |
Getting started with Shells | Extending CloudShell with Cloud Providers |
Getting started with Orchestration | API Guide |
To share your integration, follow the instructions in this guide.
