These forums are a place for learning, helping and sharing experiences with others about any of our products. Feel free to ask a question and get answers from our community and our most advanced users.
Note that these are public forums - anyone can view the discussions here.
VISIT OUR DIFFERENT FORUMS:
Announcements > | |
CloudShell > | TestShell > |
Developers > | BI (Business Inteligence) > |
This is where you can suggest your ideas to help and improve the product for everyone.
Please make sure to read the following article before posting a new idea, to get more information about the required information and ideas lifecycle.
Feel free to vote and comment on other ideas to promote them.
Thanks for everyone who suggested the ideas and voted for them.
Find, download and share integrations that can extend and enhance the CloudShell experience.
Integrations have several levels:
Certified - Officially tested and supported by Quali.
Preview - Provides a sneak peek to what the Quali team is developing. Officially supported by Quali. Feel free to experiment and comment, but please take into consideration that it is not yet tested and released.
Community - Integrations shared by community users. Feel free to look into what other users have contributed, please take into consideration that these integrations are not tested by Quali.
To learn more about creating Shells and integrating with CloudShell, use the following links:
CloudShell's Dev Guide > | Configuration Management > |
Getting started with Shells > | Extending CloudShell with Cloud Providers > |
Getting started with Orchestration > | API Guide > |
To share your integration, follow the instructions in this guide >.
I am using Quali to map layer-1 switch ports between Calient S320's. All works well when configuring one port on one switch to ports on the same switch. However, when configuring between verified (known good) ports between the two S320 switches it comes up in a one-way condition. Fiber has been tested and is good. Single mode fiber to all router transcievers, and between the two Calient devices. Quali seems to map all of the corresponding ports correctly. However one side always has complete signal loss.
Has anyone fought this battle before? It is doing this across multiple ports on all parts of the switch. The switch and Quali do recognize these ports as 'transit' ports too. There is just about zero documentation that I can find for this type of inter-connectivity yet the software and hardware both are recognizing these as 'transit'.
Answer by Jonathan Benami · Jun 28, 2019 at 04:55 PM
We fixed this once the Calient rep looked at our setup Ports were mismapped :) for the transit connections. Very simple fix under my nose. We are now mapping inter-switch between 3 Calients in our lab using Quali!
Answer by Yaniv Kalsky · Jun 13, 2019 at 07:04 PM
So when you verify the mappings in the two switches, it shows you that the mapping was done correctly between these 4 ports (2 on each switch)?
How many inter-connections do you have? does it happen only in some of them if you have multiple ones?
Yaniv
Answer by Jonathan Benami · Jun 13, 2019 at 07:39 PM
Hi Yaniv,
Indeed it does show bi-directional connections. Two ports on each switch when config one connection. I have one router on one switch, and one on the other. The two L1 switches are connected via a couple fibers on dedicated ports. Quali moves to each open transit port as new connections are made. But I am only getting light in one direction. I verified local connectivity proving the fiber and transciever optics between end routers and their respective switches. Also ran two new fiber between switches and testing with pulse (visible light) and light meter. I looked at Calient mapping. I statically mapped the ports between the two L1 switches in Quali via the Calient driver in Resource manager. I don't know what we are doing wrong.
I have 3 router devices, all single-mode and two transit ports between calients. Each one gets the same condition. Moved to different ports and the same persists. I also measured with a light meter and our original Calient that has been operational for months appears to be sending full strength to the newer Calient. However from the newer Calient to the original one I am not seeing any light. If this were a bad Calient chassis I should not be able to get ports running locally between endpoints.
Not sure if it's a software problem or a physical issue with the switch. My guess would be to the latter. But I'm wondering if anyone has done with the the L1- Calient driver shell successfully before?
Answer by Yaniv Kalsky · Jun 13, 2019 at 09:17 PM
I also think it might be something physical, but you can also try to check:
1. connect 2 routers to calient1 and create a mapping between the 2 to make sure it works well
2. connect 2 routers to calient2 and create a mapping between the 2 to make sure it works well
Yaniv
Announcements | |
CloudShell | TestShell |
Developers | BI (Business Inteligence) |
CloudShell's Dev Guide | Configuration Management |
Getting started with Shells | Extending CloudShell with Cloud Providers |
Getting started with Orchestration | API Guide |
To share your integration, follow the instructions in this guide.
Ability to create a new resource via Cloudshell/Inventory in a specific path 3 Answers
Image cannot be opened while deploying 1 Answer
MSSQL Server 2017 support - Distributed transactions requiring the MDTC service check? 3 Answers
Is there a way to disable "recurrence" reservation options? 2 Answers
